Roller Rockers, Need answer FAST!!!!
Old Aug 12, 2008 | 05:33 PM
FuzzyDiceRule's Avatar
FuzzyDiceRule
Default Roller Rockers, Need answer FAST!!!!
i FINIALLY got the ****ing pushrods, i need assistance, im tightening down the Rockers, and im unsure of the proper way to do it, ive heard to tighten it by hand until you cant turn the pushrod with your fingers, and then turn it 3/4 of a turn, a full turn, 1/2 a turn
ive heard all three
and i dont wanna **** **** up, how do i REALLY do it, a quick answer is appreciated
Old Aug 12, 2008 | 06:04 PM
Joel5.0's Avatar
Joel5.0
Pedestals or adjustable stud mounted?
Old Aug 12, 2008 | 06:09 PM
FuzzyDiceRule
Stud mount
Old Aug 12, 2008 | 06:39 PM
FuzzyDiceRule
Come on guys, i REALLY need an answer, im trying to finish my damn car and im not wanting to do this wrong and **** something up
Old Aug 12, 2008 | 06:53 PM
Joel5.0's Avatar
Joel5.0
Check the following procedure and LUK.
Old Aug 12, 2008 | 07:23 PM
AdderMk2's Avatar
AdderMk2
Banned
yea.. joel... still banned from SBFtech
Old Aug 12, 2008 | 08:59 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
with each cylinder on tdc.. tighten down polylock until 0 lash = slight drag on push rod than 1/2 turn max from there and lock it down
Old Aug 12, 2008 | 09:15 PM
94StinkinLincoln's Avatar
94StinkinLincoln
why are you banned from sbf joel?
Old Aug 12, 2008 | 09:32 PM
AdderMk2's Avatar
AdderMk2
Banned
hes not.... I am
Old Aug 12, 2008 | 09:33 PM
Hung Like a Stang's Avatar
Hung Like a Stang
this is from crane's website
Using Adjustable Rocker Arms to set Hydraulic Lifter Preload
The easiest method to arrive at proper lifter preload is when you have an engine with ?Adjustable Valve Train?. Unfortunately, since 1967 most domestic engines, with the exception of small and big block Chevrolets, have been made with non-adjustable rocker arms. The Crane Catalog shows you several ways of converting your engine to an adjustable rocker arm system. The following sections will describe how to set the preload with adjustable rocker arms.
Hydraulic Lifters Can Be Adjusted at Any Engine Temperature
Since hydraulic lifters can compensate for thermal expansion of the engine, the adjusting can be done with the engine cold; hot adjustment is not necessary.
Adjusting Hydraulic Lifters for Proper Preload
In order to adjust the preload the lifter must be properly located on the base circle or ?Heel? of the lobe. At this position the valve is closed and there is no lift taking place. You will need to watch the movement of the valves to determine which lifter is properly positioned for adjusting.
1. Remove the valve covers, and pick a cylinder you are going to set the preload on.
2. Hand rotate the engine in its normal direction of rotation and watch the exhaust valve on that particular cylinder. When the exhaust valve begins to open, stop and adjust that cylinder?s intake rocker arm. (Why? Because when the exhaust valve is just beginning to open, the intake lifter will be on the base circle of the lobe, the correct position for adjusting the intake.)
3. Back off the intake rocker arm adjuster and remove any tension from the pushrod. Wait a minute or two for that hydraulic lifter to return to a neutral position. The spring inside the lifter will move the pushrod seat up against the retaining lock if you give it time to do so. (If you are installing brand new lifters they will be in the neutral position when they come in the box.)
4. Now spin the intake pushrod with your fingers while tightening down the rocker arm. When you feel a slight resistance to the turning of the pushrod, you are at ?Zero Lash?. Turn the adjusting nut down one half to one full turn from that point. Lock the adjuster into position. The intake is now adjusted properly.
5. Continue to hand turn the engine, watching that same intake. It will go to full open and then begin to close. When it is almost closed, stop and adjust the exhaust rocker arm on that particular cylinder. (Again, when we see the intake almost closed, we are sure that exhaust lifter is on the base circle of the lobe.) Loosen the exhaust rocker arm and follow the same procedure described before in steps 3 and 4 to adjust this rocker arm.
6. Both valves on this cylinder are now adjusted, and you can move on to your next cylinder and follow the same procedure again.
