4.6 Mod into Fox?
Old Aug 20, 2008 | 02:15 PM
Stang2.3's Avatar
Stang2.3
Default 4.6 Mod into Fox?
How much Modifications do our Fox's need to fit one of them? cause there are a couple worth takin at my local JY
Old Aug 20, 2008 | 02:19 PM
FuzzyDiceRule's Avatar
FuzzyDiceRule
i believe you just need new engine mounts
Old Aug 20, 2008 | 02:33 PM
Stang2.3's Avatar
Stang2.3
if so that freakin rocks!!!
Old Aug 20, 2008 | 04:11 PM
aode08's Avatar
aode08
what kind of 4.6?
SOHC
DOHC
BEFORE 1999
OR
AFTER 1999
and WHAT VEHICLE ARE THEY COMING FROM.
The 4.6 Varies with POWER LEVELS
Old Aug 20, 2008 | 04:14 PM
FuzzyDiceRule
good point on that one, im guessing a NPI 2v should fit fairly easy, a PI DOHC may be a bit of a squeeze
Old Aug 20, 2008 | 04:28 PM
aode08's Avatar
aode08
From a guy that did it,, , , ,
"PURCHASED A AJE K-MEMBER WITH MOUNTS & I MODIFIED MY TRANS CROSSMEMBER TO FIT THE T-45 TRANS & SHORTED MY DRIVESHAFT (FRPP FOR A 96-98 MUSTANG) HAD TO SHORTEN .655" YOU WILL NOT NEED MOTOR MOUNTS IF U PURCHASE THE AJE K-MEMBER.
I DID RUN INTO A PROBLEM WITH THE ANTI-THEFT FROM THE 98 MUSTANG ECM. i FIRST USED A JUMPER WIRE AT THE PCM TO SEND A SIGNAL. THEN I SENT MY ECM OUT & HAD IT PROGRAMMED SO IT DID NOT NEED IT, ALONG WITH HAVING IT TUNED. "
Old Aug 20, 2008 | 04:34 PM
Stang2.3's Avatar
Stang2.3
In my junkyard are four 93 - 98 Crown Vic's and one 97 Mustang GT. so this isn't a simple bolt in procedure?
Old Aug 20, 2008 | 07:20 PM
holyshift's Avatar
holyshift
My buddy put a 5.4 into a Fox Body, I believe he used the AJE K member, but he put a John Deere Turbo on it and used an aftermarket computer with it. It was featured in Muscle Mustangs, the article was called "Yes Deere" if ya wanna look it up. But a very tight fit looks good though.
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
RCS02v6
Sep 29, 2015 01:46 PM
