Air bag sensor?
Old 07-05-2008, 01:11 AM
50GT
50GT's Avatar
Default Air bag sensor?
When I start the car I get five beeps that are coming from under the dash. I believe that this is the air bag sensor.At any given timewhile driving down the road I get the same five beeps. Some times it willkeep going off for 3-4 minutes, the same five beeps with abrief pause between them. The car is a 1990 mustang gt, I think it is the first year to havea drivers side air bag installed. Any help on what could cause this would be much appreciated.
50GT is offline
Old 07-05-2008, 07:39 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Air bag sensor?
you mean this sound???
http://s242.photobucket.com/albums/ff63/mjr46/?action=view¤t=airbag.flv
mjr46 is offline
Old 07-05-2008, 07:44 AM
mjr46
mjr46's Avatar
if that is the sound it is coming from the air bag module....when I converted my 92 4cyl to a 5.0 carbed set up air bag sensors were disconnected from efi harness so light flashed in the dash indicating an air bag malfunction....well duh!!! so I said I'll take care of that and remove light bulb in cluster well when you do that then the air bag module will sound off on start up for a few sec and after that every 30 min for a few sec again...if someone has removed bulb replace it and troubleshoot where prob is in air bag system if your still efi or simply unplug the harness going into the blue box behind the dash...
mjr46 is offline
Old 07-05-2008, 08:21 AM
Johnny Cash
Johnny Cash's Avatar
Hi, I have a similar problem! I think that its a ground that is not making a good contact but I don't have an electrical wiring diagram to see where I can spot the problem. would you have one? I'll let you know what my problem is if I fix it. Johnny Cash
Johnny Cash is offline
Old 07-05-2008, 09:08 PM
50GT
50GT's Avatar
Thanks, I'll check the bulb to see if that’s the issue.
50GT is offline
Old 08-20-2008, 09:52 PM
kjbauman4
kjbauman4's Avatar
I have a 1993 with 5.0 and airbag lights flashes 3 times in row, any idea what that means.
kjbauman4 is offline
Old 08-20-2008, 09:55 PM
mjr46
mjr46's Avatar
yea there is a malfunction with a component within the air bag system, you'll need to pull the code and reference code to see what part of the system has a problem
mjr46 is offline
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
Dathan
10-05-2015 05:52 AM
Explosive
10-02-2015 07:45 AM
Sixer4Life
09-28-2015 07:05 AM
Quick Reply: Air bag sensor?
