95 gt vert engine build
im looking to build an engine from block up, i heard the strokers are a good motor to build what are yalls input what should i get 302 block and bore into a 331? i want as mutch horsepower as i can get out of an n/a but also a motor that will stand up to a turbo/supercharger down the road.......give me some input on some motors thanks
if you want to use the 302 block then bore it 30 over and put in a 331 stroker kit. but if you want the max HP you can get the look for a 351 and bore it out to a 408 and SC that then you will be making some huge numbers
Sep 1, 2015 08:16 PM
