d-1 streetable?
d-1 streetable?
hey guys hopin u can give me some advise :
i've got a 92 lx with a h/c/i/ 306 eldel performers, cobra int and an e303
my friends got a complete procharger d-1 set up he barely ran 2000< miles
and has offerd my the opp to buy the complete kit injectors and mass air sensor for 2g's
will i be able to run that big of a charger at 6-8psi on pump? ( my comp is about 9.6)
meth injections fine i just dont kno if i can boost that low on that charger?
help!
help!
im pretty sure im gonna put meth on it anyways....
thnx!
good thing you posted all your specs before you asked the question , id still run around 10 psi, and you may need to run a different head gasket if it becomes a problem which it might with 9.6:1, a MLS head gasket may be a good investment (if you dont already run one), adding the meth will give you some horsepower gains as well, but there is some caution to running water/meth (windshield washer fluid) vs running pure meth, as water is corrosive but usually not a problem from what i have seen personally i have just heard of it corroding internals, just something to watch for
ive also heard of this... in drag cars where they make a pass and shut off imidently afterwards the theroy is that in a street car u keep driving it and it all dries out ima go check my build sheet c what headgaskets i have too .......
they're SCE graphite compisite headgaskets?
meh ill just take your word for it , id say your pretty well set ultimately its up to you how much boost to run but 10 psi seems a good safe number, you can also take the SN off the supercharger tag and give pro charger a call, tell them your running at xx altitude with 9.6:1 compression and you were wondering a safe boost for pump octane, they will crunch some numbers etc, and get back to you, altitude has another role to play as well since barometrics have a huge impact on boost
