Which caster camber plates do you recommend?
After I lowered my car I was no longer able to have my car aligned to specs. I'm researching caster camber plates to correct the problem, but Im not sure whether to go for stock replacement 3 bolt kit or is it really worth the trouble to get the 4 bolt kit?
Anybody that has experience with these please give me any info you have. Thanks alot
-Green5pt0
-Green5pt0
RE: Which caster camber plates do you recommend?
I talked to someone in the tech department at maximum motorsports today and he said the Steeda STB "might" interfere with the MM C/C plates. Since I won't know until its too late, is there anyone out there running a Steeda STB with MM C/C plates? Thanks,
-Green5pt0
-Green5pt0
If no one is running Maximum Motorsports Caster Camber plates with a Steeda strut tower brace, is there anyone running Caster Camber plates of any kind with a Steeda strut tower brace? I am just wondering which plates will deffinitly work with a Steeda STB.
Thanks guys,
-Green5pt0
Thanks guys,
-Green5pt0
