Injectors big enough??
Old May 16, 2005 | 02:51 AM
redmustang83596's Avatar
redmustang83596
Default Injectors big enough??
I have a long list of mods so i dont really wanna post them all in here, but you can check out my site for a full list --> http://www.cardomain.com/memberpage/672744
Do you think that 24# injectors are big enough, or do you think i should go bigger, like with 32# or sumthin like that?
Old May 16, 2005 | 03:16 AM
Quik's Avatar
Quik
Default RE: Injectors big enough??
maf too small. it should be 5 mm larger then tb for optiomal performance. 24s should be good to mid 300 crank. get close to 400 then 30s are needed.
Old May 16, 2005 | 03:23 AM
redmustang83596
What about with a shot of nitrous?
Old May 16, 2005 | 03:26 AM
Quik's Avatar
Quik
dry or wet.........i went 30s for my dry shot...dry shot requires more fuel. small shot your fine with a wet shot. you got like 150 then i would up grade them if you did a wet kit
Old May 16, 2005 | 03:35 AM
redmustang83596
I believe it is a wet kit, and a big one at that. It works off of a plate, not a nozzle. I havent ran it with spray yet, but it can be adjusted from 50-300 in two stages, so with both stages i can run as much as a 600 shot. I plan on running one stage, at first, with about a 250 shot and see what i get.
Old May 16, 2005 | 03:40 AM
Quik's Avatar
Quik
lmao a 250 shot you want to run..i personally wouldnt do it, thats for an all out nitrous motor
Old May 16, 2005 | 03:42 AM
redmustang83596
its built for nitrous, there has been a bigger shot on the motor before in addition to a superchager, so im not worried about blowing my **** up, thats not the problem, i just hope that it wont run lean on just 24# injectors.
Old May 16, 2005 | 04:06 AM
Quik's Avatar
Quik
what timing was the motor at with that big ofa shot?
Old May 16, 2005 | 04:25 AM
redmustang83596
no idea, i bought the car from my cousin and he had the shot. Im getting the timing set a little advanced over stock for when im not running spray, but when its activated i have a MSD box that takes out like 2 degrees i believe, not too sure, im still in the process of installing it.
Old May 16, 2005 | 04:29 AM
Quik's Avatar
Quik
if you only take away 2* for htat large of a shot. you will have a dead motor.....reason i asked is rule of thumb is minum of 2* for every 50 shot of juice. so if the motor had a 250 shot that is 10* or more. so base timing is 10 btc now it would be at 0 btc or lower..............oh by the way what head bolt size you running?
