Emergency tire size question!!!
Here are some numbers to help you draw your own conclusion;
Height (over all diameter) & Width are computed from tire size and will have some variance between manufacturer.
Stock size
225/60-15 H = 25.63" W = 8.85"
Your current tire size
245/45-17 H = 25.68" W = 9.64"
Option you listed
255/40-17 H = 25.03" W = 10.03"
Stock size
Option you listed
The deal is for 4 tires, so I'll be doing the back to match. I would imagine that if the wheel is shorter, the tires will turn faster, so the speedo would register that I was going faster than I was in reality. The question is, how MUCH faster? It soulds like I'll see a reduction in the number of speeding tickets in my future! LOL Now, would I be right in assuming that they have a driven gear to match the shorter tire?
Stock size
Option you listed
Stock size
Option you listed
Ok here are some more numbers to compare using the stock rear gear ratio of 2.73, in 4th gear which would be a 1:1 ratio on a 5 speed, and using 2000 rpm for motor speed.
225/60-15 = 55.85 mph
245/45-17 = 55.96 mph
255/40-17 = 54.54 mph
As you can see not a huge difference, but would be noticed in mpg performance if you track it closely. Hope this helps out some.
(yes I'm some what of a nerd and I have created spreadsheets to quickly calculate these kind of things)
(yes I'm some what of a nerd and I have created spreadsheets to quickly calculate these kind of things)[/QUOTE]
Well, the opposite side of the coin is that it would be like getting a mini rear gear job, right? A minute change in acceleration? LOL What if I went with some 295/25/13s? Hahahaha!
But seriously, is that enough of a difference to change the speedo driven gear, or do they only come in 5MPH increments?
Now the thing is your running 9" wide in front... i am too. People are saying they have 245 up front with no issues..on ponies (8"). 9" wide will rub. I think i have 255/40 nitto nt555's up front. Perfect with tire clearance but my rims shave alittle. It looks like it rubs the control arm with my 1-1/2" drop up front. Id like to know how to stop it too. 9" wide up front sucks...if i had to do it again i wouldnt. Steering is limited compared to before plus the sound when you hit the arm sucks.
i was thinking the same thing about the a-arm but that will only change when i switch to coilovers. I wonder how much shaving it will actually give..and if its even worth it. Rac limiters would seriously limit the steering. Good luck getting into a parking spot in one shot.
