how to check tps voltage
<FONT size=2>1) Loosen the two screws holding on the TPS, (The screws can be very stubborn, so make sure you have a good quality screw driver that fits snug and has a long handle for lots of torque, or you might strip the heads) just enough to able to swivel the TPS with force.
2) Pierce the "GREEN" wire with the pin and hook the positive (+) lead from the voltmeter to it.
3) Ground the negative (-) lead from the voltmeter. Use a good ground, like the engine or other grounded metal source.
4) Turn your ignition key to the run position, but do not start the vehicle
5) Rotate the TPS until you achieve .98 to .99 Volts (For stock or slightly modified engines).
6) Tighten the screws on the TPS and recheck.</FONT></P>
<FONT size=2>Troubleshooting</FONT></P>
<FONT size=2>If the maximum or minimum voltage you can obtain is close to the above recommended voltage setting (.98-.99), but the TPS just won't turn enough to get it right, you will have to modify the TPS. If you get a very low voltage reading, make sure you have an accurate voltmeter and your connections are solid, if so, you need to replace your TPS. If you have no voltage, you have a bad connection or a bad voltmeter. Rarely, if never, will a TPS be in such bad shape, especially if your car still runs good.</FONT></P>
<FONT size=2>P.S. I copy and pasted this</FONT></P><edited><editID>mdvaldosta</editID><editDate>37922.4939351852</editDate></edited>
i bought it and its got like 3,000 on it. i got the professional products 70mm throttle body with adjustable tps sensore and it came with one. i ment 15$ they are like 29$ at the autoplace.
