just ordered nitto drag radials
OK I did it I just ordered a set of nitto275/60r 15 tires for my 8in wide welds. any feed back on the nittos would be welcome. they cost less than the m/t drag radials also I was worried about a 295 fitting my rims and in the fender wells sence they recomend a 10in wide rim. I am thinking about polly bushings for my stock control arms and boxing in my lower control arms ANY THOUGHTS?????
RE: just ordered nitto drag radials
The Nitto's don't hook nearly as well as the BFG's or the M/T Radials, but will last a bit longer, and are still better than Regular old 40,000 mile street tires.. You should hook up just fine with them with the size you are getting, that's a big tire.. I would recommend just getting a set of aftermarket control arms, both up/low as they are inexpensive, and you'll never have to worry about them again.. Remember, don't forget about those torque box's...
ORIGINAL: 91hatchgt
ORIGINAL: sastangman
also dont forget to put in new energy suspension upper control
arm axle bushings,you may have to torch out the old crappy
rubber ones but get those for sure.
what psi should I run?? and what rpm do you think I will be able to launch at. Right noe I leav at idol then get into it so I don,t smoke 1st and 2nd???
[IMG]local://upfiles/11405/387EDE5444DE476DA51297E4F8340ED5.jpg[/IMG]
