Help with Hooking!!!
Can i get some input for ya'll on my best rout to go for traction out of the hole? Im slidding all the way into third and its killing me! I know a good set of tires (pending on street or strip) are critical but suspension wise, whats my best bet?
Part numbers and names would be greatly appreciated. Thank's.
this is a pretty awesome set up right here. strange engineering adj shocks/struts eibach pro drag springs, hotchkis CC plates, i also have UPR upper and lower control arms, sub frame connectors, 3.73 gears(pending install), TQ box reinforcements(pending install) and some MT e/t streets(on back order). this is a receipee for cuttin 1.5 60's
that or maybe gernading my T5
to give you an idea this all cost approx 1700 dollars all new(give or take a hundred)
fixed
subframes on these uni body cars are one of those "best bang for your buck" mods
However, I put a set of full slicks on my wifes basically stock vert. Shaved about 7 tenths of her times.
i wish i had a tube K member(like yours) w/ Arm's that have spring perchs so i can keep my set up and toss out my old crappy rusty nasty horribly massivly ridiculously heavy POS k memeber
I fell you on that one I can almost get a tire off the ground but i need less weight up front damn k members can run into the 700+ range with all the parts you need for them like coil overs and stuff
K-member and a arms are like 450.00. Not to hateful.
i really like the UPR kit but they dont have the proper A arms to go with it. can you link me to a good site with tube k member that also sells arms with perches. i'm goin for broke on this suspension!
or can you just buy the k member, bump steer kit and bolt up your old A arms?
http://paracing.com/product_info.php...bb9090e9d560ab
If you are seriously considering them, let me know and I'll pm you the contact info for the guy I bought it from. I was the only one that took the time to answer all my questions about the products. I guess he really wanted the sale. Plus I had a few other ppl that used these parts recommend the PA Racing stuff.
