So I just got my car up and running again. And im idleing the car and it idles perfectly. When i grab the throttle and put it up, say 1/2+ throttle it pops really loud. I havent set the timing just yet, just did it a little by ear. Is this because the timing is off? or could it be lack of fuel (tiny tiny fuel pump (60lph) with a H/C/I 302)
yes it would, but that fuel pump is almost half of a stock 302. upgrade the pump and do the timing right, you'll be fine.
i know im getting a fuel pump tomorrow, the car has just been down for a month or so, so i was making sure it ran before i started tearing other things apart. So if I set the timing and it still pops, what can that mean?
post a video of the noise if it still does it, could have a lean condition, or vaccum leaks contributing to lean condition, but take it one step at a time, do the above then go from there
well you could try doing a base idle reset by disconnecting your battery for like 30-45 mins and disconnecting the IAC. then run the car and get it to operating temperature and set the throttle body screw then shut it off then plug iac back in
