Flood Or Not?
Flood Or Not?
i rebuilt my car about 1 1/2 years ago. it has a cobra intake, 75mm tb, 76 mm maf, World Windsor Jr. 180 heads, 1.6 rockers, stock injectors, longtube headers, x-pipe, built AOD tranny, 4.10 gears.
my question is i have found a set of 24lb. injectors (blue tops), that have had flow work. the guy showed me the paperwork from a Ron Anderson Motorsports that he spent $324.00 on having them flowed. the paperwork states that they flow within a 99% of each other. my question is with my car i planned on buying these injectors, installing a 155 or 190 lph pump and i bought a holley pressure regulator. will these boost my car or just flood it out?
please help before i waste my money!!
set the PSI correctly on your regulator 24#ers would be more ideal for your build anyways. you are somewhere around 300 HP which would be close to the stock 19#ers duty cycle max. i say do it if you got the money.
well i lucked out on the injectors. even though he had the flow work done, he sold them to me for a 100 bucks. he also has a MSD Pro Billet distributor for sell to for two bills. so i now have the injectors, the old lady just picked them up on her way home from work. what is around the correct psi they should run?
i hope so, it seems like right now, it strains itself. i dont know what its problem is. not to mention i fill my tank up as much as i eat, and im not little by no means, lol. and it empties itself out as much as i do, lol. seriously. youd think that stepping up the fuel system would mean worse mileage. is that true also?
