well i ruined my volt gauge so i cant check right now but last time i set my tps, it was .98 or 1.98. i cant remember which is the proper one. anyways, i know i did it right at the time.
you should be reading the green wire. hook the positive electrode to the green wire and the negative electrode to any ground. 5volts is like WOT. you need to adjust that thing
you dont check all the wires, you only check the green one. the black is a ground, not sure what the other is for. when setting the tps you only check the green wire
