Bad rear end??
Old Sep 26, 2008 | 07:44 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
you may have a bad axle bearing or carrier or pinion bearings, start with easiest first, = axles remove them and look at surface for pitting or gauling where bearing would ride, the "whir " noise you describe sounds like a bad bearing noise would make
Old Sep 26, 2008 | 09:15 PM
ryan_89_mustang's Avatar
ryan_89_mustang
The thing is you don't exactly hear a noise the whirr is just describing how the vibration is like its not a solid vibration its like a cycle this is felt mostly in the shifter.
Old Sep 26, 2008 | 09:16 PM
mjr46's Avatar
mjr46
some vibration in the shifter is normal, mine vibrates a little
Old Sep 26, 2008 | 09:22 PM
ryan_89_mustang
This isn't little I would take a video if I could get my camera working even the pedals start to shake.
Old Sep 26, 2008 | 09:33 PM
mjr46's Avatar
mjr46
are all the mounts tight and not broken on engine and tranny...any drivetrain components touching the body???
Old Sep 26, 2008 | 09:39 PM
ryan_89_mustang
I think I'm going to throw it up on a set of ramps when I'm off on Sunday and see what I can find. I will check the back tires, should there be any play at all if there is that means the wheel bearing is gone right? Also is there a way to check the motor mounts other then looking at them the motor sits straight and the mounts don't seem to look half bad the trans mount is questionable and the cross member as well. Thanks you're being a great help I appreciate it.
Old Sep 26, 2008 | 09:43 PM
mjr46's Avatar
mjr46
an excessively bad wheel bearing would cause a lot of up and down movement, check the rubber on the mounts and make sure it is not torn
Old Sep 26, 2008 | 09:46 PM
ryan_89_mustang
Alright thanks a lot, I will post back with results when I take a look.
Old Oct 1, 2008 | 05:21 PM
ryan_89_mustang
Update:
The trans mount is pretty well shot the rubber was completely falling apart. The crossmember and bushings are also shot one tube is rusted right through. So I have new bushings/crossmember coming.
New problem is I have a squeak or a chirp when I am starting off in 1st It sounds like it could be coming from the pass side. This noise used to be there intermittently but now it is much louder and constant. also it is in rythem with the drive train or tire like chirp....chirp...chirp and gets faster till about 2500rpms then stops. There is no noise when the car is idling in neutral
Old Oct 1, 2008 | 08:06 PM
ryan_89_mustang
t t t
