Trick Flow top end kit problems
Old Sep 28, 2008 | 11:26 AM
dennisdiecast's Avatar
dennisdiecast
Default Trick Flow top end kit problems
hey guys i'm new here and require some of your expertise...
i installed the Trick Flow twisted wedge track heat top end kit on my car, upgraded to a 70mm throtle body, headers, 24lbs injectors... and my car is having really bad idling problems, and whenever i would give it a shot of gas the rpm doesn't go up instantaneously like it used to, it lags.
Now, i called up the store where i pretty much bought everything (mustangsunlimited.com) and they told me that it will be really hard to tune the 88 mustang with this kit because its not a Mass Air Flow system, so they suggested i buy a whole MAF kit and then tune it cause it will be easier and it will have more power in the long run.
Anyone have any idea if this is true? if yes, then great i know what i have to do!!! but is there anything i could do to avoid buying all of this?
please keep in mind that i'm new to all of this... hope someone can help.
Dennis Pavia
diecast
Old Sep 28, 2008 | 12:11 PM
calfroper_06's Avatar
calfroper_06
from what i heard it is true to properly get a sd stang to run correctly with high performance ungrades you need to convert to mass air. my car was converted when i bought it so i really cant say yes but im pretty sure you need to.
Old Sep 28, 2008 | 12:33 PM
saleenpride1986's Avatar
saleenpride1986
your fuel pressure might not be high enough anymore, you could be running too lean. Also the MAF needs to be properly matched for your injectors to get the right calibrations.
Old Sep 28, 2008 | 12:54 PM
capri debris's Avatar
capri debris
You must convert to mass air. SD takes it's reading from the vacuum on the intake and now all that has changed. I did the same TF swap as you and also converted to mass air and even still I had idle problems.
Old Sep 28, 2008 | 02:24 PM
dudeboy's Avatar
dudeboy
True,
You need to let the ecu account for the new cam, and the injectors.
Converting to MAF will take care of both of these issues...
OR
Look for someone to custom tune the SD ecu... but good luck finding anyone, as there aren't many places that will mess with SD.
dennisdiecast
did you ever manage to get rid of the idle problems? or you still having them...
Old Sep 28, 2008 | 02:41 PM
capri debris
Still have them because I haven't taken the car to the dyno yet to be tuned properly.
Old Sep 28, 2008 | 02:44 PM
crusin92red5.0's Avatar
crusin92red5.0
i recently installed the kit and i'm still in the process of figuring out my idle issues
Old Sep 28, 2008 | 02:54 PM
86 5.0L's Avatar
86 5.0L
or install a PMS system, they are SD and much more detailed then a MAF system :P
Old Sep 28, 2008 | 04:16 PM
dennisdiecast
well at least i know where i should start to try fixing this problem... thanx for help guys!
