Oil Pan Stuck
Old Oct 29, 2003 | 12:20 PM
vfast's Avatar
vfast
I ♥ Acer
Default Oil Pan Stuck
be sure to prime the engine before starting
Old Oct 29, 2003 | 12:37 PM
Muscles's Avatar
Muscles
After I finish swapping the Oil Pump?</P>
Old Oct 29, 2003 | 04:37 PM
Muscles's Avatar
Muscles
What do you mean prime?
Old Oct 29, 2003 | 04:41 PM
Sean's Avatar
Sean
Turn the pump to get oil where it needs to be, before starting.
Old Oct 29, 2003 | 06:19 PM
vfast's Avatar
vfast
I ♥ Acer
you can use a drill..I use an ole dist made to fit my drill to prime it to around 20 psi coarse there is no cam gear on it..
you don't have to do it. I just do..I mr safe when it comes the things.<edited><editID>vfast</editID><editDate>37923.6813541667</editDate></edited>
Old Oct 29, 2003 | 06:44 PM
Muscles's Avatar
Muscles
You guys lost me if its not too much to ask can you please explain in detail???? Im new to this changing the oil pump?!?!?</P>
<IMG src=smileys/smiley5.gif border="0"></P>
Old Oct 29, 2003 | 07:01 PM
89muscle's Avatar
89muscle
take the coil wire off the distributor and ground it to your intake and crank it over for a few seconds so you can build oil pressure, or get a socket and a speed wrench and put it down into the distributor hole and crank the oil pump drive shaft untill you get some pressure.
Old Oct 29, 2003 | 07:44 PM
Muscles's Avatar
Muscles
Thanks 89</P>
</P>
Old Oct 29, 2003 | 08:02 PM
nostang's Avatar
nostang
Make sure you got the two 1/2" bolts way in the back,kinda behind the pan.You probably won't be able to get the pan all the way out,at the shop we always just dropped the pan down as far as it would go and then unbolted the pump,there is a 9/16"nut holding on the pickup tube on the number 3 main bearing bolt.It can be kind of hard to get to.
Old Oct 29, 2003 | 08:24 PM
Muscles's Avatar
Muscles
I got those 2 bolts, and I lifted the engine to clearance the oil pan out, so ther eis a 9/16 bolt hloding the Pump? wait the pick up tube???? #3 main bearng bolt??? where is that??? Hmmmmm
mrtrodonet
Sep 19, 2020 03:12 PM
b8checker
Oct 8, 2015 12:55 PM
UrS4
Oct 3, 2015 06:23 AM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
