1995 brake question
1995 brake question
for all you guys with sn95's or someone who knows on the 95 master cylinders what ports are designated to what, front port to rear brakes and rear port to rear brakes doing a 3-2 port conversion and have all the stuff i need just need to know where to put what
95 GT master cylinder right? not the cobra? it makes a difference on how you set it up.
http://mjbobbitt.home.comcast.net/~m...n_94gt_kit.pdf
what i was wondering is if i should hook up both front lines to the front port and then hook up the rear line to the rear port i was thinking it would keep brake lines togethor instead of tieing the front line with the rear line
yea, with the GT booster its a 4-2 port conversion. 3-2 port conversion is cobra i think if i read it correct.
so to answer you question both rear breaks feed into the front port and both front breaks feed into the rear port
thats per the PDF i posted which shows how to do the conversion with the GT booster.
well then i guess you saved yoruself a step. personally ive never done it. hopefully i will soon someday. but! i cant speak from experiance. just try both front breaks to rear port and visa versa. worst case she dont work.
i see, i checked all the diagrams that site provided with all the other combos and they all look to be rear breaks to front port and visa versa
so i'm going to assume that is the correct way to hook it up, wish someone with hands on experience would chime in to just verify.
