** Help ** Car won't stay running!
Hey guy's, After having my head's rebuilt,new timing chain & oil pump, new coil, Trick Flow Stage 1 cam & 8lb Super Charger, My car is hard to start and if it does start it's hard to keep running! It also makes a kind of like poping sound from the intake manifold. Is it a fuel issue because I still have the factory fuel pump? Would a bigger pump fix this??
Thanks guy's
Thanks guy's
sounds like your timing is off.
make sure your #1 piston is at TDC when you stab your dizzy and make sure the rotor is pointing at the #1 cylinder sparkplug and not 1-2 teeth off.
https://mustangforums.com/forum/5-0l-1979-1995-mustang/293134-how-to-properly-stab-your-distributor.html
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
