lower intake
oo wow um, i dont have three holes like that at the back of the intake, or any open ports at the bottom of the upper, all i have is one T coming out the back of the upper, from there i had the PCV, that connects to the PCV at the bottom of the intake, and the S for the vaccum tree, wowo it look like i really F'ed up here im not sure at all where to plug these things in. for the fuel pressure regulator, i have one of those small vaccum lines that connects to the EGR, CONNECTED to the regulator, i think its a thin black hose(plasstic), is this at all right
I'll assume that when you opened the box you got all of this?
In the diagram I posted earlier the back of your upper should look like this?
And the brass fitting for the vacuum should or could be placed like this.
no man i got mine used. all i have is the T that is at the back of the intake, the other 2 holes are blocked off, then i have a small connector near the throttle body like in the picture, but its on the other side, its visible is you pop the hood. and i dont have that peice thats connected underneath the upper intake, where does that black hose go?
