t-5 problems question
Old Oct 6, 2008 | 01:30 PM
Ketis's Avatar
Ketis
Default t-5 problems question
i recently installed a t5 in my 93 vert and i have a problem and im not exactly sure what is the cause
when i put it in first it goes in fine, as i slowly let out the clutch it pops out, i can get it to take first if i hold it there but it will try popping out, but once its in there and im moving it will stay
also 2nd gear is completely unusable
i can put it in 2nd gear at a stop and slowly let out the clutch and it will just grind also when im driving it does the same gear, so i dont have 2nd at all
the rest of the gears work perfectly
so im curious what is the culprit of the tranny problems
thanks,
Keith
Old Oct 6, 2008 | 01:42 PM
jman511115's Avatar
jman511115
Where did you get the T-5? New/rebuilt or used? Could be clutch adjustment too...
Old Oct 6, 2008 | 01:47 PM
Ketis's Avatar
Ketis
i got it from a guy who wrecked his car
i didnt pay a whole lot for it so yeah
Old Oct 6, 2008 | 10:38 PM
Ketis's Avatar
Ketis
any ideas of what parts are broken/worn out?
Old Oct 7, 2008 | 12:04 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
the blocker rings for those gears may be damaged or sincronizer teeth ae bad on the gear hubs of those gears = possible internal tranny issue as long as clutch cable is properly set/ adjusted
Old Oct 7, 2008 | 01:38 AM
Ketis's Avatar
Ketis
yeah, i tried adjusting the clutch cable today, that didnt make it any better
it i adjusted it too much and it started to slip so i know its the tranny
looks like i get to learn how to rebuild a t5 lol
Old Oct 10, 2008 | 08:48 PM
Ketis's Avatar
Ketis
so i got the transmission pulled and i started taking it apart
im not really sure what is bad but maybe these pics would help someone tell me whats wrong so here they are
any help would be appreciated
Attached Thumbnails t-5 problems question-dscf0530.jpg   t-5 problems question-dscf0531.jpg
Old Oct 11, 2008 | 01:53 AM
Ketis's Avatar
Ketis
if im not mistaken i think this would be the cause of all my problems..
a broken 1-2 shift fork
would that be the cause for the problems of not having 2nd and popping out of first?
musnicki
Sep 23, 2015 07:11 AM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 04:12 PM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
