charging problems
well at idle it should be 13.5-14.5 around there. You need to try to figure out if you alternator is putting out the right charge. Since your alternator tested good twice, there is got to be bad wiring somewhere in the system. I say start right by the alternator to prove that its giving out the right charge too. good luck.
well my problem went away for a little while, it just started charging out of nowhere, well the car has sat for a couple weeks so i go to drive it and now it is not charging again....
replaced the regulator and that wasnt it...i have thoroughly went through all the wiring except for the one wire that goes through the firewall to the guage but that should not be causing my problem right???
stangin1996gt
Sep 21, 2015 11:01 AM
