Jolting problems
Jolting problems
Ive got a reoccuring problem with my '89 5.0 Gt 5 speed, you guys may be able to help. When cruising along at 25-40 mph with hardly any throttle the car is constantly jolting and missing slightly, as soon as you touch the gas its fine. Ive had lots of people give me different answers from clogged injectors to a faulty TPS - has anyone had the same problem?? Ive also bypassed the air pump and stripped all the emisions gear from the engine ( I live in Grand Cayman and luckily we dont have emissions tests here!), this ive also been told may cause problems?
Thanks
Thanks
RE: Jolting problems
whens the last time you did a tune up? air filter, spark plugs gapped properly, fuel filter, oil change etc. also replace the dizzy cap and wires. make sure your timing is set anywhere from 10-13 degrees or so if you are running 87 octane.
ORIGINAL: fordguy17
no way, i always keep the rpm above 2K, cam doesnt like to be driven lower then that, it happens all the way up to maybe 3K and its only when im not on the throttle, if i step on it it goes away until i let off... sry if i took your post, but we have similiar problems....
