gettin hot!!!
gettin hot!!!
ok so my car seems to heat up fast as **** then stay that way for awhile the got to normal again for a little then baxck to hot. i just bought a new radiator and fan from american muscle and im hoping that solves the problem but if not what could it be?
so more so in stop and go?? if make sure the elec fan is working, there is a high and low speed operation to it which the fan is controlled via imputs from the ect and when temp reaches certain degree low speed comes on and then if that's not enough high speed operation comes on, but all this is commanded on by the ccrm, the black box close to your overflow bottle on a pedastal.....you need to make sure fan is coming on when car is running hot
Not to highjack this thread but I have an observation on the over heating or rather running hotter than usual. MJR46 and others what do you think. I have no smog pump, no cats, timing at 14 degrees. no problems with running hot. I plugged the EGR off on the intake manifold and it runs really warm, close to overheating and this is running at highway speeds. Could this be caused by something being compensated by the ECU OBD1. Maybe not getting the hot exaust gases into the heads anymore and the system running lean at highway speeds with cold air instead, and creating more heat when system sees EGR opening. Could this possibly be an issue??????? Thanks MAC
bradleyb
11-27-2015 07:50 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
