No Air from front Vent
I have a 93 Ford Mustang GT Conv. All of a sudden my air conditioner stopped blowing out the front vents. I will blow from the top deforster vent, and from the floor vent but not out the front panel vents. I was told that it could be a vacume line that has come loose somewhere. I saw a white, blue, back, and red vacume line. Can someone show a diagram where these lines run from start to finish. Also which one would be to the front panel (white, blue, red, or black)?
check vacuum supply line in the engine compartment...it is usually on the passenger side of the firewall by the heater core...make sure its not damaged or unhooked...
also these car have a big problem with the switch assembly itself cracking and leaking... listen for a hissing from inside the dash...
I had that problem too with the air only coming out of the defrost vent. I had put an aftermarket cd player in and snagged a line behind the radio. I found the line and slid it back on this little pump and it works fine now. I hope that helps!
I am having the same issue from my '94 conv. I will take a look at all the vac lines and let you know what i find. I remember it happened not to long after i did an obessesive cleaning pulling off any thing i could remove. thanks for the good info people.
fastbackford351
Sep 12, 2015 09:42 AM
Sep 1, 2015 08:16 PM
