when should fuel pressure register?
exactly what the title says. does it register when the key is turned on, when you start cranking the engine, or does the engine have to me running to get a correct reading?
just curious, cuz i'm messing with my car and i have a guage hooked up to the fuel rail and i can't seem to get it to register past 15lb. the car won't even idle so i can't check it will its running thanks.
Are you hearing any sounds from the pump when you turn the key? Is this a new problem or has it been happening for awhile? Did it just start after you made some changes (regulator, lines, pump, etc.) I know, all basic questions... But sometimes we overlook the obvious.
is there a right up on how to test the connector or is it fairly easy? what should the voltage be? if it is a bad pump do you think i get a warranty or something, cuz i literaly have put maybe one or two miles on the thing and maybe 1 hr and 1/2 running time on that pump.
