Speed Sensor
Old Nov 7, 2008 | 09:51 AM
Cobra-Z's Avatar
Cobra-Z
Default Speed Sensor
Just purchased a 94 Cobra and the speedomoter doesn't work, i have checked for power at the Tran sensor and have no voltage , any suggestions?????????????????????
Old Nov 7, 2008 | 10:11 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
that would be because there is not suppose to be any voltage on the wire...you are testing it wrong!!.....the sensor bolted to the tranny is a small gear driven permanent magnet signal generator that generates an AC signal proportionate to the vehicles speed.........you should use a multimeter and unplug the connector and turn your meter so it tests for ac voltage and connect the two leads to the sensor and spin the wheels fast enough so you can see if a ac signal registers on the meter.....voltage reading should be between 1.3 and 6.1 volts...if the sensor tests good, then pull the cluster and check wiring from pin connection on cluster down to pin connector at sensor connection = loop leads in series = 1 on sensor harness end and other up to appropriate pin on cluster connector = gy-bk wire = signal wire ...........pk/o wire = ground..I assume you know proper testing of circuitry testing for grounds and continuity of wiring using ohms on the meter..if wiring tests good = faulty speedo head unit/cluster
Old Nov 7, 2008 | 11:24 AM
Cobra-Z's Avatar
Cobra-Z
Thanks ,Dude
Old Nov 7, 2008 | 11:31 AM
Cobra-Z's Avatar
Cobra-Z
Default Springs & shocks
I want to lower the car also, I have heard various Manufactures springs, shocks and struts, what do you recomend ?
Old Nov 7, 2008 | 11:39 AM
mjr46's Avatar
mjr46
ebaik or ford racing??..I have coil over so never went that route
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Oct 3, 2015 06:23 AM
BeatnikFink
Oct 1, 2015 08:00 PM
