wiring help
i need some help on putting a sn95 cooling fan on my 89,i can make a way to mount it up but im trying to figure out a good way to wire it up,i want to try and wire it up where both speeds work,does anyone have alot of knowledge of the sn95 fan that can help me,im thinking of wiring the high speed up to the a/c and the low speed up to a temp probe in the radiator,but all of the kits at the parts stores are only rated at 30 amps,and they have small gauge wire and my sn fan has pretty good size wire,can someone give me some ideas how to wire it up.would putting a relay on the high speed and using the a/c to acuate the relay work,like run from the battery to the relay then the fan,would that work?but im lost on how to figure out a way to use the low speed with the fan controller.what controlls the fan on the sn95's?i need some hlep if anyone can give me some input.
jwog666
Dec 27, 2021 08:09 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
