17X9 Bullitts w/ 275/45's...will they fit?
Old 11-17-2008, 09:59 AM
camaroeater
camaroeater's Avatar
Default 03/04 SVT Cobra wheels on a fox?
found a set of 17X9 bullitts w/ 275 wide tires which i don't think will fit the front. I also found a set of 03/04 cobra wheels and the guys doesn't know the width. I have lincoln rotors and 5 lug conversion.
camaroeater is offline
Old 11-17-2008, 11:34 AM
primetime5.0
primetime5.0's Avatar
275's wont fit the front, and on both of those wheels your going to need a spacer to clear the hub
primetime5.0 is offline
Old 11-17-2008, 11:37 AM
redpony88
redpony88's Avatar
the 275's wont clear the front but they should be fine in the back, just grab some 245's for the front
redpony88 is offline
Old 11-17-2008, 11:41 AM
Timspony
SVT Section Moderator
Timspony's Avatar
I did a 5 lug conversion on my 1991 GT using Lincoln rotors...You will have to be carefull with your rims choices because of the front wheel bearings...I used '95 Cobra R wheels (will clear the front bearings), 17x9, Car lowered with 245's up front & 275's in the rear...No Problems...
Timspony is offline
Old 11-17-2008, 12:59 PM
camaroeater
i just picked up the cobra wheels. I guess there off a 99' cobra not a 03' and the tires on them are 245/40/r17. Hey primetime, will having upgraded front/rear disc brakes allow them to fit w/o the spacers. I can't wait to get these on, i hope i don't need spacers.
Old 11-17-2008, 01:43 PM
primetime5.0
you'll need 94+ brakes to get away with not using a spacer on the front
Old 11-17-2008, 01:53 PM
camaroeater
yep, just found that out. They fit the back, but not the front. What size spacers do you have? Hopefully I can get the spacer locally, like at discount tire or something. thanks primetime!
Old 11-17-2008, 01:54 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
I ran a 3/8" on mine, mash the bearing cap flat and modify the center cap.
PRO50SC is offline
Old 11-17-2008, 02:10 PM
camaroeater
when i put the wheel on the front the studs barely go in the holes to hold the wheel up. I wonder if i might need something close to 3/4" or 1"? thanks pro!
Old 11-17-2008, 04:42 PM
86HOGT
86HOGT's Avatar
Wont' the spindle end rub and eventually tear through the dust cap though?
86HOGT is offline
Quick Reply: 17X9 Bullitts w/ 275/45's...will they fit?
