tdc on #1
tdc on #1
what is the easiest way to bring the motor around to tdc on #1 cyclinder on the compression stroke with the heads off? the reason i ask is cuz next wed when i get a break from school i am going to pull the pass side head off and check the block and head with a straight edge and i might as well re stab the dizzy so i can check that off the list of reasons my car runs like crap
also what is the tolerance for a warped block/head? sorry i don't know the exact way to ask it. i heard 3 thousandths. is that correct? thanks
set motor on tdc before you pull it apart!! pull plug and roll motor over until you feel air pushing past your finger while holding finger over hole then pull cap and make sure rotor is pointing at no 1 on cap..fyi you don't need to pull the head to see if your block surface or head surface is warped, if there are no coolant leaks and compression test comes back fine, it would be a waste to pull heads.
On a running engine, there is an easier way to determine compression stroke. Simply remove the distributor cap after noting which post is number one. Turn the crankshaft to TDC with the rotor pointing at the number one post.
When you are putting an engine together or don't know it's position, that's when you have to use the thumb over the plug hole trick.
So what is the tolerance anyway?
Also when i scrap the old remembrence(?) of the gasket off the block with a razor blade there is always a trace of it being there kinda like an imprint on the block is that normal?
Is there a better tool to do this with?
