Question about IAC.
Old 11-22-2008, 12:51 PM
Cbuss54
Cbuss54's Avatar
Default Question about IAC.
Where exactly is the IAC sensor located and whats the best approach to cleaning it? Im having a lean misfire when its cold and im trying to figure this out.
Cbuss54 is offline
Old 11-22-2008, 12:58 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I doubt the Iac is causing the misfire.....could be carbon build up ...remeber carbon act as a sponge and will absorb a/f and cause a lean misfire on start up, good seafoam treatment can cure this, also try cleaning the maf
mjr46 is offline
Old 11-22-2008, 01:04 PM
Cbuss54
Cbuss54's Avatar
I've tried the seafoam treatment via the gas tank. Whats the other way of using it exactly?
Cbuss54 is offline
Old 11-22-2008, 01:25 PM
mjr46
mjr46's Avatar
read the can..all the gas tank way does is clean the cumbustion chambers , excluding the intake....it generally goes in the brake booster...full instructions are on the can
mjr46 is offline
Old 11-22-2008, 03:39 PM
cammedlx
cammedlx's Avatar
Or search for a vacuum leak..Lean pop through the intake,erratic idle...Could possibly be the problem.
cammedlx is offline
Old 11-22-2008, 05:23 PM
Cbuss54
Cbuss54's Avatar
Just did the seafoam through the brake booster, smoked a decent amount. Still misfires. How often can i do the seafoam treatment?
Cbuss54 is offline
Old 11-22-2008, 06:16 PM
mjr46
mjr46's Avatar
have you done a koer/cylinder balance test to see which cylinder is misfiring???
mjr46 is offline
Old 11-22-2008, 06:33 PM
Cbuss54
Cbuss54's Avatar
I've done the Koeo test, looking to do a compression test sooner or later. I'll do the koer test soon. Whats the cylinder balance test?
Cbuss54 is offline
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Question about IAC.
