Engine building questions
hey, ive got a couple questions, were starting to get the 306 for the RX7 back together...
first do GT40 heads require the bushings to fit a 7/16 stud to a 1/2 inch hole?
also, doed anyone know of a good online guide thing with all the torque specs and such? and the torque sequences
lastly, do i need to get new main bolts?
i know there is a write up in the "tech articles" on the torque specs, but not the torque sequence. you'll need a haynes or chilton manuel for that or you might find in on the web.
and i wouldn't see a reason to change main bolts
if they were off a 351 they would have 1/2" holes requiring the reducer washers, but gt-40's never came on a 351 in stock form.
okay.... ill buy the bolts with the 1/2 inch thingy,
anyone care to enlighten on the break in when the swaps done
the way i think i was told was, run it for a while (30 mins?) to let the rings seat, check for leaks etc, then change the oil at 50, 1000, 3000 and then every 3k... cutting the filters to check for bearing failure
anyone care to correct me? or is this basically it?
Once you figure out what head bolts you are going to use and what style lube sealer then start in the center of the head and work your way out in a criss cross fashion to the ends of the heads at about 20Ft lbs. Then do the same thing at 50 ft lbs and make the final torque to your specs. Go over each head twice for final torque.
If you didn't machine the block use the same main cap bolts that came out or go to ARP Bolt. If you plan on Studing the mains you need to have it line honed using the studs torque to spec. It will create cap distortion.
All GT40 iron heads require them because they are 1/2 studs.
