Engine building questions
okay.... ill buy the bolts with the 1/2 inch thingy,
anyone care to enlighten on the break in when the swaps done
the way i think i was told was, run it for a while (30 mins?) to let the rings seat, check for leaks etc, then change the oil at 50, 1000, 3000 and then every 3k... cutting the filters to check for bearing failure
anyone care to correct me? or is this basically it?
If you run it in, in the car just go out for a casual 30 minute ride (roller cam engines) just down the highway. It needs to be under load diung break in so it doesn't run lean and hot. If it's flat tappet you will absolutly need to keep the rpm moving from 2500 to 3000 for around 25 minutes while the cam develops a wear patern.
cool, thanks for the response
as for rotating assy installation, i just need to get a good amount of lube on the bearings, correct? what about the cylinders when installing pistons, should i get some motor oil on the walls for good measure? anything else like this that is easily looked over?
I also soak the timing chain and roller lifters for a few hours just prior to installing them. Most good chains are true roller and while they have some grease in them from the factory I do this so the chain doesnt have a dry start up and the first few minutes of run time can get you not only some stretch but some material residue. I soak the roller lifters so the small needle bearings in the roller will fill with oil again to prevent dry start up.
When assembling the top end I put a drop of assembly lube inside the pushrod cup of each lifter and the top of each push rod and on top of the valve just before the rocker goes on. If using roller rockers I will soak them in oil as well.
Gary Ugarek
63
12-11-2015 02:01 PM
Calizic
08-28-2015 01:46 PM
HIS S-197
08-10-2015 05:47 PM
