Looking for 300rwhp
Looking for 300rwhp
Hows it going everyone I am new to the site
Basically Im want 300 rwhp
My car is a 1994 gt it made 272 rwhp I cant exactly remember the tourqe but i know it wasnt any higher then 280. So far my I have a 302 with 1000 miles stock rotating assembly, Trick flow twisted wedge heads, Holley Systemax II intake manifold, Afm N41 Cam, Comp cam pro magnum 1.6 rockers,Underdrive pulleys, 70mm throttle body, 24lb injectors, power pipe, velocity maf sensor, Mac Long Tubes 1 3/4 3 inch collectors way To Big, 2 1/2 h pipe, mac catback, 3.73s
If any one has any input on what i can do to help reach 300 rwhp its appreciated
I do not want to add any power adder, or change the bottom end yet
Sadly, many combos using the TrickFlow heads never make it to the 300rwhp mark. However, I've seen them make some good torque numbers.(I made 271rwhp & 311rwtq through an AODE using the TW heads). Also, what kind of dyno did you use? A Mustang dyno usually reads quite a bit lower than other dynos. You have basically maxesd out your car when it comes to mods, other than FI or building a stroker motor, which you do not want to do. Porting the heads a bit should get you close the the 300 number. However, like MJR(Mod) would say, take it to the track and see how it runs. 300 is just a number. How it performs on the street is what really matters.
What was the tempurature you dyno'd at and whats your elevation?
But as most said... numbers don't mean much, its how it runs
there is hidden power in the drive train... aluminum Driveshaft could free up another 5-7 to the wheels... and a Lightweight flywheel would do teh same with another 7 or so rwhp...
