Positive Crankcase Problem!!!!
I hope I can get alittle help with this problem. I have a 93 5.0 with a stock 302 with Heads and Cam the bottom end is stock and has about 60k on it. Whenever the car is at wide open throttle I notice oil was coming out of my breather filter on my valve cover. I installed a crank case ventilation system and I notice now the air and oil pushes the PVC Valve out of the back of the intake. I've asked around and some people tell me 2 just put a breather filter in place of the PCV Valve. Has anyone had problems like this or does anyone know of a solution? P.S I know I probably have blowby at the pistons but I have insufficient funds to rebuild the motor right now.
make sure the mesh filter screen under the grommet in which the pcv valve plugs into is not plugged up/ restricted
http://www.latemodelrestoration.com/...0%201&comp=LRS
Wow i think i just figured out my own problem, I'm guessing that screen works kind of like a baffle which when i put my car together wasn't really thinking about it and i just never put it back on the new intake...well hopefully problem solved...thanks for the advice.
If you were to install it, the crankcase pressure would still be there.
Do not use a PCV with a breather, the breather only acts as a large vaccum leak as far as the PCV is concerned. Use either the breather or the PCV, not both. The PCV system is better suited for ventialation in a stock to medium hp engine due to a possitve vacuum pulling from the engine.
Problem is, it just doesn't look cool enough for some people so they throw a breather on to make their car look faster.
