starting problem
Old Dec 14, 2008 | 09:11 PM
gtmustang1090's Avatar
gtmustang1090
Default starting problem
i can not start my mustang with turning the key i just replaced the cellinoid. and it still wont crank until i connect the 2 posts with a screw driver. then it starts right up. would you guys think its a ignition switch?
Old Dec 14, 2008 | 09:39 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
the small wire going to the selonoid in the crank position should have 12v on it, use a test light to check, if it is not hot in crank, trace wiring back to ignition switch , elec portion of it may be bad
Old Dec 15, 2008 | 06:46 AM
gtmustang1090
well i figured it was from there back to the ignition. i already bought a new switch it was like 13 dollars lol... i figure i might as well change it while i have the steering column apart. the guy i bought it from swore it was the starter and wanted to argue with me till i was dead but i dont think its that cause i wouldnt be able to start at all right?
Old Dec 15, 2008 | 09:54 AM
gtmustang1090
alright i took out the plastic piece fromt he ignition sswitch.. it looks like the part that has to two yellow wires in it is melted alil up there? any advice
Old Dec 15, 2008 | 12:52 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Yeah, repair the wires and put in a new switch.
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
cvarner131
Aug 17, 2015 07:38 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
