4.6 to 5.0
and this is logically the best advice. sadly enough as time progresses these things get more complicated. to swap an engine with an engine that is not a stock option is not so easy anymore. i REALLY wanted to drop a 460 into my 03 mach 1 after i cracked the block, and warped the motor. after looking into it, it was next to unrealistic. though i would say it doesn't take that much to put a 302 in a 96-98. clearly buying the car you want is the best way to go.
I'm another one for th PI swap. I think you will see an impressive difference. If the motor and components in your car already work fine i don't see the reason to go from a modular to 5.0. For the 302 idea i would buy a whole car that is worn out, you could prolly come across one for cheap.
......and the 94, 95 GT's are tied to an even bigger stump.
It was really just a smart *** answer which is the general flavour of this forum. The original poster actually deserves a proper answer.
If the car he has now is a 4.6L. Explorer 4.6's with PI heads is an easy swap. If it's a V6, then swap in a 4.6L.
Engine to engine the 4.6L is superior to the 5L in every way. Stock and built but I think we've worn down that topic many threads ago.
There are a couple people running good times with NA 2v's, but they have fully built blocks, custom heads etc revving to 8000+rpm. Stock block 2v's have 1 in the high tens and the rest are 11+ second cars. 5.0's on the stock block can run single digits and there are tons of them that do... because its easy and cheap.
--To the OP, since you already have the 4.6 youd be much better off just doing a PI swap. It would probly cost more, and definitely take more time to do the 5.0 swap than a PI swap, and stock 5.0 vs PI swapped 4.6 the 4.6 will win without a contest.
TO OP, either buy a GT or Cobra with a 5.0, or do a PI swap, swaping from a 4.6L to a 5.0 is going to cost a ton of money.
To the poster about 5.0s being slower, not so. Car and driver netted a 14.9 in the 1/4 with a 5.0 as opposed to a best of 15.1 with the 4.6L. One of the best times I've seen for a stock Sn-95 5.0 was 14.2s in the 1/4 with nothing more than flowmaster exhaust (not much of an upgrade if you ask me). The best 4.6L time I've seen was 14.9s which was C&Ds 5.0 time.
Serriously the 4.6L just doesn't have the push the 5.0 has despite them being rated at the same HP. I'd bet against any 96-98 4.6L against a comparable 94/95 5.0, or any 5.0 for that matter. There is no replacement for displacement.
Yes, I would definetly agree that it is easier to buy the car u want already that way, but here is my situation.
I have had three mustangs so far 2-1996 Gts and a 2000 Gt and the nonpi 4.6 engine is slow and everyone knows what kind of money it takes to make a mod motor fast.
I currently don't have a mustang at all and was thinking about going witha 5.0. I really would like to stay in the sn95 body style but haven't found a 94-95 anywhere close forsale. I was asking the question because i did find another 96 with a lot of miles and wondered how hard the swap would be.
Can someone please tell me what kind of power a 5.0 would make with a HCI swap and what parts to use. Also, how much power will the stock 5.0 rotating assembly take(this is where a 4.6 falls short and costs a lot of money)
thanks guys
thanks guys
thanks guys
thanks guys
i would really like to have a mustang with around 400rwhp. Basically looking for just a fun street car that won't need to be a DD at all and maybe in the future take to the track if i can spend some serious money on it.
