AOD to T-5
Old 01-05-2009, 05:13 PM
GT350son
GT350son's Avatar
Default AOD to T-5
What parts are required for a AOD to T-5 conversion? And what cars have the t-5 that can be swapped into the 84 gt350?
Thank you.
GT350son is offline
Old 01-05-2009, 06:36 PM
STROKED_LX
STROKED_LX's Avatar
Im looking to do this swap too, would like to know.
Would i have to cut the trans tunnel to let the shifter come up?
Can i use the same AOD ECM?
Will my AOD drive shaft be ok?
Can i still use my AOD crossmember?
Is the trans mount different?
Speedometer cable same?
The pedal assembly will be a pain in the *** but i figured out that part.
STROKED_LX is offline
Old 01-05-2009, 06:43 PM
FORD TOUGH
FORD TOUGH's Avatar
A t-5 of course not any newer than a 93
Bellhousing
flywheel
clutch kit
clutch cable and quadrant
pedal
and maybe a crossmember
If you plan on racing a recommend a billet steel flywheel and a blowproof bellhousing because at high rpm's you clutch or flywheel can explode and it could possibly cut your toes off.
Here is a chart that compares t-5 with the gear ratios, torque ratings, and input shaft lenghts. http://www.allfordmustangs.com/Detailed/349.shtml
FORD TOUGH is offline
Old 01-05-2009, 06:44 PM
aode08
aode08's Avatar
Good Used GT T-5 Transmission
Bellhousing w/ Bolts
Clutch, Pressure Plate, Flywheel
Pressure Plate Bolts
Clutch Fork & Cover
Transmission Wiring Harness
Computer
Upper & Lower Shift Boots
Shifter & Handle
Transmission Mount
Cross member
Drive Shaft Yolk
Pedal Assembly
Clutch Cable
aode08 is offline
Old 01-05-2009, 06:57 PM
STROKED_LX
STROKED_LX's Avatar
What would happen if i used the same ECU?
Old 01-05-2009, 07:00 PM
cammedlx
cammedlx's Avatar
Nothing because the fox's trannys are not computer controlled.
cammedlx is offline
Old 01-05-2009, 09:53 PM
GT350son
GT350son's Avatar
Who has the right answer? I see two answers. One with computer and one without computer
GT350son is offline
Old 01-05-2009, 09:56 PM
Modular_Madness96
Modular_Madness96's Avatar
The manual had a little more of an agressive tune if you can even call it that.
Modular_Madness96 is offline
Old 01-05-2009, 09:57 PM
Modular_Madness96
u can use either one though.
Old 01-05-2009, 10:06 PM
302army187
302army187's Avatar
you can use the SAME driveshaft and yoke.
this website http://www.promotionpowertrain.com/1691136.html
they have a list of parts, and sell them all.
really GREAT company to work with, and thats where ill be buying my transmission from most likely.
you do NOT need a new computer, but some computers go crazy and have issues.
so its possible that you will need a new computer, but highly unlikely.
if you plan on rebuilding your tranny, heres a good website article.
http://www.fordmuscle.com/archives/2...uild/index.php
i also ordered a DVD from this guy.
badshoeproductions.com
good luck.
302army187 is offline
Ryan Fitzpatrick
09-14-2015 02:21 AM
CarrieS
09-01-2015 01:00 PM
ImprtsNightmare
11-08-2003 11:57 AM
MustangGT95
07-31-2003 02:56 AM
DougBlevins
03-24-2003 03:42 PM
Quick Reply: AOD to T-5
