73mm Caliper Question
Old 04-22-2009, 12:19 AM
.boB
.boB's Avatar
OK, I found the picture I was looking for. This is the 73mm SVO cvaliper mounted to a Fox spindle. Notice how the bleeder points almost straight up. It would appear that it would allow for easy bleeding. BUT, the is actually a picture of how to do it the WRONG way.
When installed correctly, the bleeder points straight back, and is almost parallel with the ground.
Soon after taking this picture, I learned the correct way, and swapped the calipers.
This picture was taken a couple years later. It's a little difficult to see. But the bleeder is properly oriented.
.boB is offline
Old 04-22-2009, 09:18 AM
mAnYsTyLeS
mAnYsTyLeS's Avatar
Just an FYI... on Maximum Motorsport's website, they state the following under the SVO caliper kit they sell...
Best used in conjunction with a rear disk brake conversion kit, and our SVO master cylinder, BMC-1. Not recommended for use with rear drum brakes.
http://www.maximummotorsports.com/
If that wasn't the case, then I would have purchased 73MM calipers as well. Instead, I just opted in for a new pair of 60MM.
mAnYsTyLeS is offline
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: 73mm Caliper Question
