fuel pressure/ timing
Old Jan 9, 2009 | 04:18 AM
1995mustang818's Avatar
1995mustang818
Angry fuel pressure/ timing
well guys i just about had it with this car lol..its my buddies notch it has some gt40 aluminum heads f cam holley system max 2 intake 65mm t/b 76mm maf bbk fuel pressure regulator long tube headers x piped i was wondering if you guys could help . what fuel pressure do you recomend and what should i set the timming at? also how much rwhp do think its at ? thanx alot guys
Old Jan 9, 2009 | 09:02 AM
FivePointOhh's Avatar
FivePointOhh
in limbo
FP should be set @ 39psi vac line off. timing should be around 10-14* spout out. 10* is the factory setting. you can up it up if you'd like for performance but know you may need to run premium fuel to do this. $$
for rwhp? hard to say...maybe 270-290. not too sure about the heads performance but that cam is pretty lame.
Old Jan 9, 2009 | 09:22 AM
15austin's Avatar
15austin
That cam should make decent power IMO, but I think that intake is pretty lame. But I agree fuel pressure @ 39psi and timing @14*.
Old Jan 9, 2009 | 09:37 AM
Portmaster's Avatar
Portmaster
I'd say about 275 at the wheels, I think the Throttle body is kinda lame, lol (just kidding)
Old Jan 9, 2009 | 09:46 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
The system max isn't that bad of an intake but I wouldn't have chose it. Like already said 39psi no vac and 10-14 for timing. you can probably bump up the pressure some once you get it going and maybe a little more timing if you use higher octane gas.
Old Jan 9, 2009 | 12:05 PM
15austin's Avatar
15austin
My bad, I was looking at the 93 cobra intake in his sig was being lame....Holley is a good intake......Sorry
Old Jan 9, 2009 | 01:28 PM
1995mustang818
dont worry about it bro lol its my buddies car it his cash lol i walk him all the time with my little junk yard set up still on a stock cam lol ...thanx alot guys ill let you guys know how it goes
Old Jan 9, 2009 | 01:51 PM
1995mustang818
just so you guys know its still on 19lbs injectors and a stock fuel pump
musnicki
Sep 23, 2015 07:11 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
Sep 2, 2015 08:40 PM
SYNY5TER
Sep 2, 2015 01:35 AM
