turn signal problem! need some help
Old Jan 10, 2009 | 10:28 PM
1990fox5.0's Avatar
1990fox5.0
wear exactly is it behind the glove box, what shape and color is it
Old Jan 10, 2009 | 10:32 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
It looks identical to the one you already replaced in the fuse block
Old Jan 10, 2009 | 10:43 PM
1990fox5.0's Avatar
1990fox5.0
is it next to the computer
Old Jan 11, 2009 | 08:52 AM
ttocs's Avatar
ttocs
push you hazard switch in and out a bunch of times to clean it out. It gathers dust on top of the steering wheel and then if you happen to use it once just pushes the dust into the switch. It is self cleaning so just push 5-6 times and see if both lights flash.
Old Jan 11, 2009 | 09:36 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
No, more towards the center console.
Old Jan 11, 2009 | 09:54 AM
Joel5.0's Avatar
Joel5.0
LH of the glove box or RH of the center console.
Old Jan 11, 2009 | 01:37 PM
mustangmike33's Avatar
mustangmike33
well imo, its a bulb. obviously if it was the flasher going wrong wouldnt the left side not work either? so how about checking the front and rear right turn bulbs. one of them is out. that should fix your problem unless you've already done that!!
Old Jan 11, 2009 | 01:52 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
No, a bad flasher can cause the exact symptoms he has. I've seen it happen plenty of times
Old Jan 11, 2009 | 09:58 PM
az 88 5.0's Avatar
az 88 5.0
yeah i would check the flasher as well, if thats not the issue double check your connection on the ignition switch that can cause similar issues, maybe maybe not?
Old Jan 13, 2009 | 09:38 AM
rhstang2's Avatar
rhstang2
did u check the bulbs when the bulbs go on fords they don't flash
