Question for the sunroof owners
My car has had a leak since I bought it, and even though it has what appears to be fairly new weatherstripping, the water still makes it way through.
The only viable answer I can come up with is that the 4 drain tubes are clogged or pinched in some manner.
Can anyone tell me where these tubes end? Or maybe a creative way to reinsert them to the proper place so I can remove them to inspect/clean?
I pulled one out about 4 inches and it took me about 45 minutes to get it to slide back down the windshield channel, so I can imagine doing the whole length of it will be quite a task.
each tube ends in each corner of car. left front under pedal area. right front under passener foot area. left rear just after rear tire as well as right rear. i had simular problem what i did was too open sun roof and take a glass of water and poor it into sunroof channels. then i looked under car to see where they came out. i notcied which one was clogged then i took a metal coat hanger down the cloged drain. also i had a leak in center of windshield so u might want to check that also. what is wet in car and can u see where the water is dripping
i use compressed air & blow down each hole to make sure they are clear < dont use to much pressure>. i also applied silicone around the 2 plastic holders < the ones that are in the body of the car> check out "fox mustang restoration" they have a gasket kit & parts for the sunroof
