Couple of questions...
With the 5.0 mustang, I know I want a 5.0, but one of the options I'm considering is picking up the 2.3L 4 cylinder because of the cost of initial investment. (don't worry guys, I'm definitely going with a blown 5.0)
The questions I have are, would a 5.0 and matching transmission be a direct bolt on, or will there be a bit of cutting and welding?
I figure with the kind of rebuild I have in mind, it would be a good idea to save money, also I wouldn't be wasting a potential cherry car on a race car build. Plus it would be easier for me to find a notchback instead of the hatchback if I'm going for a 2.3L to start from.
Secondly, do 5.0's have 02 sensors that have to be eliminated/tricked in any way, or can I go with an offroad exhaust with little to no issues?
Lastly, is the 5 lug conversion really worth it, or am I better off sticking with the 4 lug? Seems the 5 lug setup improves my options, but still...
Thoughts, ideas, etc? Is finding a cheaper 2.3L car more cost effective than buying a 5.0 stock that you're going to rebuild anyway?
Last question is whether or not getting a 2.3 is more work than getting a 5.0 (if you plan on replacing EVERYTHING).
So it won't throw codes without cats, good (and I assume if needed you can get useful information from the sensors still?). Also the 5 lug isn't essential but gives a lot more options, I can understand that.
If I can save money going with a 2.3, I don't want it to be at the cost of a lot of fabrication work that I might screw up. If it's relatively straight forward, then I'd be all for it.
I guess its kind of a trade off the 5.0 notch will be more expensive up front but it already has the motor, trans,rear end etc
the 2.3 will be cheaper up front but you'll have to buy all those parts and convert it
I just want to know if it can be done without cutting frame, can I simply bolt in new motor mounts and be done with it, or do I have tocut and weld to transplant a 5.0.
I'm having a difficult time finding a page that documents it thoroughly.
Found some information here:
http://5lmustang.com/site/4cyl_mand.php
update: found somebody selling a 4cylinder locally for 1000$. I am going to try talking it down. If I can get it cheap I'll pick it up, would be nice to be able to drive around for a few days to figure out what's wrong. And it's a notch.
If I can SAVE money by getting a 4 cylinder I'm all over it. If it's POSSIBLE to go witha 4 cylinder first then it's what I'll do. Yes if I can find a GT in great shape with less than 70,000 miles for less than 3,000$ I'd probably do that, but if I found a 4cylninder car that was waiting to be donated to a good project, guess which way I'd go...
yes its a direct bolt in provided you have the mounts, and remember the 2.3 are gutless so the torque boxes are usually in great shape unlike a lot of stick 5.0s where they are abused and torn up. a lot of 2.3 cars werent loaded down with all the power bs like a gt would be so the car is gonna be lighter right off the bat. besides most 5.0s are beat to hell so there gonna need fixing anyway, when i did my conversion i went through each part before doing the actual swap, so i had a fresh motor, trans and rear, same with the suspension, your gonna want to change it so why not do it the way you wanna, there is no better time, you have to rip the 4 cyl crap off anyway. i liked doing the 4 cyl to v8 swap cause i now have the car exactly the way i want it and i couldnt be happier with it. just my 2 cents, good luck
