Drum Brake Problem
Old Jan 22, 2009 | 08:32 PM
Doomstein's Avatar
Doomstein
Default Drum Brake Problem
I was doing a brake job on my 1990 GT and man they were a mess. When I pulled the drum and shoes the brake bar (little bar between the shoes with the spring on the end) was in rough shape and the spring actually disintigrated when I took it off. Anyone know where I can pick up a new bar and spring?
Old Jan 22, 2009 | 08:37 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Autozone, brake hardware kit will have what you need and for the bar ask for the bar, they should have it
Old Jan 22, 2009 | 08:43 PM
Doomstein's Avatar
Doomstein
I saw that they have the bar, but the spring is the key. I hope they have it.
Thanks man.
Old Jan 22, 2009 | 08:48 PM
mjr46's Avatar
mjr46
http://www.autozone.com/selectedZip,.../selectZip.htm
http://www.autozone.com/R,3868123/ve...ductDetail.htm
http://www.autozone.com/N,14400008//...eResultSet.htm
Old Jan 22, 2009 | 08:49 PM
mjr46's Avatar
mjr46
check my links they have it all, carry the part numbers to them and walk away with he correct parts
Old Jan 22, 2009 | 09:06 PM
Doomstein's Avatar
Doomstein
Already got the self adjusting kits and the all-in-one kits. Also got the nifty 2 in 1 brake spring pliers and retaining spring tool. Only thing I was missing was the bar and spring. Actually now that I think about it I should probably replace the wheel cylinders too. They look pretty awful. Anything I should watch out for?
Old Jan 22, 2009 | 09:09 PM
mjr46's Avatar
mjr46
I know whaat spring you are looking for and I could of swore I bought one at Vato-zone?? but if all else fails the dealer should have them
Old Jan 22, 2009 | 09:10 PM
mjr46's Avatar
mjr46
not really, just make sure e-barke cables work
Old Jan 22, 2009 | 09:16 PM
HACKGT350's Avatar
HACKGT350
yeah soak the brake line fittings with some kind of penetrating oil for a while so you can get the lines out of the wheel cylinders with out a problem
Doomstein's Avatar
Doomstein
Roger that. Thanks again
Tivo304
Aug 28, 2023 12:19 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
mungodrums
Oct 7, 2015 04:01 AM
musnicki
Sep 23, 2015 07:11 AM
