t5?
t5?
ok so i am bout to order a rebuild kit for my trans just want to make sure it needs rebuilt the trans will not go into 2nd gear over 1500 rpm i am thinkin that it is a syncro and this is the kit that i am lookin to get
http://www.yearone.com/serverfiles/f...ain2.asp?cat=F
before ordering a thing you need to pull it out and apart and inspect synchronizer teeth on the gear hub for those specific gears, cause if they are mushroomed flat, a new gear is needed all a rebuild kit comes with is blocker rings , bearings and other stuff....check out the gearbox.org.....I just rebuilt mine with their kits at a great price
this one...along with a new cluster kit.......both worked well
http://www.thegearbox.org/catalog/it...32/3531891.htm
it will be 188 with shipping is this the right kit
http://www.yearone.com/serverfiles/f...d=&hid=&iMode=
