Stumped car falls on its face past 3k
I'm completely lost, I have replaced every thing new plugs,wires,cap,rotar new dizzy, dyna mod thing that goes on the dizzy coil was upgraded with a crane fireball coil, allso replaced the fuel filter and cleaned the maf and tps the car isnt throwing a check engine light. Does any one have any idea what could be causing this?
i think it is that little module you have for the distributor. one of my buddys had an accel one and it messed his car up, and it was fine when he took it off and kept it stock. what is done to your car? clean your sensors
I went and bought the actron cp9015 code scanner from autozone and used it.
When I did the koeo test I got code 67 and 33 which says egr valve posistion sensor or pressure feedback egr sensor indicates egr valve is not opening or egr valve position sensor or pressure feedback egr sensor indicates egr valve not seated properly. When I did the koer test I got codes 41 91 and 33 again 41 is exhaust gas oxygen sensor voltage signal always lean does not switch, 91 is exhaust gas oxygen sensor -signal coltage allways indicates lean either during engine run self-test or normal engine operating conditions. Now my question is could any of these codes cause the problem im having right now?
did you check into some new o2 sensors? i'm not sure if they cost a lot or not...but that will probably fix your problem. is your MAF clean? there is a cleaner called MAF cleaner it comes in an aerosal can and it works really nice
ShaneB26154
35
03-04-2021 04:05 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
