BBK H-Pipe...ugh
Old 02-17-2009, 06:26 PM
snakegriffin5_0
snakegriffin5_0's Avatar
Default BBK H-Pipe...ugh
So I got my new BBK h from Summit today and was disappointed to find it came in two pieces (comes together at crossover). I went with the BBK instead of the Summit because I knew the Summit was two pieces, and thought the BBK was one.
Any opinions on the two piece design? I am not so sure about it, the way I figure it is just one more opportunity for a leak.
Any thoughts are helpful...Sorry if this has been discussed.
snakegriffin5_0 is offline
Old 02-17-2009, 06:27 PM
wowvfast
wowvfast's Avatar
it's in 2 pieces to save you the over size shipping prices
wowvfast is offline
Old 02-17-2009, 06:36 PM
1988TTOP
1988TTOP's Avatar
it will be fine have it welded together or use a muffler clamp
1988TTOP is offline
Old 02-17-2009, 06:40 PM
snakegriffin5_0
Default RE
Well it came with a clamp, and I understand why its two pieces, I guess I was more curious if anyone has had trouble with their similar mid pipes. Still have a month or so before I get the car out, so plenty of time to get a different one if I want.
Thanks again.
Old 02-17-2009, 06:46 PM
Timspony
SVT Section Moderator
Timspony's Avatar
it will be fine! + simple to take off in the future if needed!
Timspony is offline
Old 02-17-2009, 07:15 PM
93 LX FiveO
93 LX FiveO's Avatar
i welded mine
the catback flanges like to leak too. i also welded those.
93 LX FiveO is offline
Old 02-17-2009, 07:35 PM
camaroeater
camaroeater's Avatar
you be glad its in two pieces when you go to install it, you'll have more room for adjustment.
camaroeater is offline
Old 02-17-2009, 07:40 PM
mustangsneverdie
mustangsneverdie's Avatar
mines held together wth a muffler clamp and it's able to to move around but it doesn't leak
mustangsneverdie is offline
Old 02-17-2009, 08:37 PM
S-Trimmed302
S-Trimmed302's Avatar
You will be GLAD its a 2 piece when you go to install it and when you go to Remove it!!I dont recommend Welding it at the H Pipe use a Band clamp to clamp it together.Look at it this way when you decide to remove it,sell it and move onto something else you will just have to remove the clamp and it will fit into a shippable box whereas if you weld it your screwed you will be stuck selling it locally.Not to mention it installs
much easier in 2 pieces....Been there done that.
S-Trimmed302 is offline
Old 02-17-2009, 10:36 PM
AdderMk2
Banned
AdderMk2's Avatar
stop being such a ****ing baby and just put it on the car
AdderMk2 is offline
Quick Reply: BBK H-Pipe...ugh
