Next Engine Mods?
All - I have been accumulating some parts lately and am now thinking about the next phase of my 90 LX Stang 5.0 project. Here are the mods I currently have:
- Mild rebuild approx 15k miles
- Vortech S-1 blower w/3.33 pully
- Eddy Performer Intake, upper & lower
- Trick Flow TW Heads
- 24# injectors
Here are mods I am considering - Parts I have:
- Install FMS F303 cam
- Installing 255lph fuel pump
- Install 42# injectors
- Pro-M 80mm MA
- Install performance fuel injector rails
- Install Aluminium pulleys
- Install duel electric fan
Questions: Are there any other mods I should consider in this next build-up? Are any of these mods a concern? What else should I consider? What kind of performance should I expect with this set up?
I plan to take the car to a engine dyno turner rigth after these mods...
- 24# injectors
- Pro-M 80mm MA
not tryin to be a ***** about correcting ya mjr, but i believe he said he had trick flow tw heads. + on the custom grind cam over the letter cam
maybe a good set of drag radials would do ya good
Well the engine was rebuilt by the previous owner - I have all the receipts. It looks like the rods were polished and peened with hardend cap bolts. The crank was cleaned up, etc. I don't think a girdle was installed.
T-rex fuel pump,, 255lph, fuel pressure reg stock fuel lines can haddle a good amount of hp, good cam- anderson or custom grind, 70mm tb, 76m c&l maf, 3.55 or 3.73 gears, spal 11in duel fans, battery relocated,
Calizic
Aug 28, 2015 01:46 PM
inyadreems
Aug 21, 2015 09:10 AM
