Creaking sound in first gear
Old Jun 14, 2005 | 02:52 AM
sabearn's Avatar
sabearn
Default Creaking sound in first gear
I have a 95 gt that I recently purchased with 125k on the engine. When I am either going slow in first gear and accelerate there will be somewhat of a creaking sound or when I slow down and im in first, most of the time its when im turning into parking lots or turning onto the street. Its loud somewhat like a creaking door. Anyone know the problem?
Old Jun 14, 2005 | 03:16 AM
settled4automatic's Avatar
settled4automatic
Default RE: Creaking sound in first gear
is it only when turning? the "Creaking door" thing sounds like maybe upper strut mount bearings?? with the engine running, have someone turn the wheel back and forth while you put your ear next to the front strut mounts in the engine bay -- hood up here -- listen for that creaking door noise. i fixed some of those on a Le Sabre today at work :-D
Old Jun 14, 2005 | 03:27 AM
sabearn's Avatar
sabearn
only if im turning really slow in first gear.
Old Jun 14, 2005 | 03:48 PM
paulstang's Avatar
paulstang
95 trannys are pretty loud to but it could be other things to
Old Jun 14, 2005 | 04:32 PM
sabearn's Avatar
sabearn
Yea, when I was pulling out of a parking lot, some guy yelled out, "its your springs" and im like thanks. But really I have no idea what it is
Old Jun 14, 2005 | 04:53 PM
ChristopherCamel's Avatar
ChristopherCamel
my old 95 stang did that..check struts and tie rods..its probably not the tranny since it more than likely would of broken by now..my car used to make this awful noise at about 5-10mph and i replaced tie rods and it fixed it...it was rather embarassing to drive and have people stare
Old Jun 14, 2005 | 08:16 PM
86gt5.0HO's Avatar
86gt5.0HO
U-joints on drive shafts can make that noise too. But if it does it when you turn the wheel it is proly your strut bearings.
-If you have someone look at the spring while you turn the wheel it will probably "twist" the spring and then jump back. Thats the noise you are hearing, the spring winding up and jumping back.
-Another thing you can notice with bad strut bearings is after turning corners, the steering wheel will tend to want to go back in the direction you just had it a little.
mtgldr
Feb 3, 2024 09:00 PM
Nick Oliver
Oct 17, 2018 04:22 AM
musnicki
Sep 23, 2015 07:11 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
