i need help
Old 03-14-2009, 02:15 PM
lx5.0
lx5.0's Avatar
Default i need help
ok so i just finished installing the gt40 intake and i had to pull the distribuator to insatall and now i tried to restab it and followed the steps on the tech article, and i started my car and it started and could also hear it was not in timing correctly so i shut it off and tried to restab it again and nothing i try to start car now and it wont start it just cranks what do i do
lx5.0 is offline
Old 03-14-2009, 03:05 PM
lx5.0
lx5.0's Avatar
so i went back to check it again and i noticed i forgot to put the tie down screw on so i put it on and car starts and i leave it idleing for a while then turn it off and i try to start it again and nothing it just cranks could this mean i have a bad tfi
lx5.0 is offline
Old 03-14-2009, 03:34 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
have you set timing with a light and with spout out??
mjr46 is offline
Old 03-14-2009, 03:37 PM
camaroeater
camaroeater's Avatar
your dizzy is probably off, you need to locate top dead center (tdc). Id would do a search on how to do this procedure or maybe someone will chime in and tell you.
camaroeater is offline
Old 03-14-2009, 04:17 PM
OnyxCobra
OnyxCobra's Avatar
Stabbing the distributor isn't that easy, I did everything exactly like the writeup said and mine was still off a tooth. By using a timing light i was able to figure out which way the disty was off and was able to remove and correct it. You'll know pretty easily when it's right.
OnyxCobra is offline
Old 03-14-2009, 04:48 PM
lx5.0
lx5.0's Avatar
well i took the tfi to get checked at autozone and they said it was bad so i got another one bolt it on and car started and i shut it off again and try to start again and same thing, no start just crank could something be burning the tfi
lx5.0 is offline
Old 03-14-2009, 06:27 PM
lx5.0
lx5.0's Avatar
i dont know what it is this is weird i start the car and then i turn it off and try it again and nothing just cranks i already took the coil to get check and it was good dont know what it could be the car was working fine before i did the whole switch over to the intake mani
lx5.0 is offline
Old 03-14-2009, 08:42 PM
lx5.0
lx5.0's Avatar
anybody have an idea what it can be
lx5.0 is offline
